About the memory problem
hello, I try to input a signal into the program , and I try to run the VI. But it said : ''not enough memory to complete this operation'' , and it said : '' Aborting the Facade VI has left the XControl in an inconsistent state . To cover from here, right click on the XControl and select Advance->Update XControl. If the VI hosting the XControl is in run mode,then right-click and select Update XControl ''
Who can give me some suggestions about this problem . There is the VI Program under this article.
(2,760 Views)
Accepted by topic author 劉彥均
Your "time steps = 1" input is way to small and will generate 0.25GB of 2D data alone.
Set "time steps = -1" and things will work just fine with your data.
From the help:
"National Instruments recommends that you set time steps such that the number of rows in the wavelet coefficients does not exceed 512. If you specify a small value for time steps, this VI might return a large number of wavelet coefficients, which requires a long computation time and more memory."
(2,705 Views)
Thank you for your help . I also try to reduce the length of the signal(one part of signal) . I found an interesting thing . I make the time step to 1000  and reduce the length of the signal . my graph is ok .
After you share your tips , my graph(all signal) is also ok  .
Your tips are very useful . Thank you  .
(2,696 Views)
