About the working of NI9233 with NI USB 9162 module
Sir/madam
I am using NI9233 module with NI USB9162  for acquiring voltage data. When i was using DAQ signal express in labview2009 for acquiring the data, the  output value is a number and at the end with m or u. What's this "m or u"for example 1.900'm'
and
i connected a 2 volt DC supply to the module but the output of the module is in millivolts. Why is this down fall of the signal
should i install any exe file for acquiring data for it ?
Kindly assist me in correcting the mistake i am doing
Regards
Lijesh
Message 1 of 1
(2,324 Views)
