About.vi issue in Labview 2012
Did you open the code for the about?  When I attempt to open the code, it is looking for System.dll.
Going into the [About Help] - Get App Version Info.vi, your .NET call is out of date.  I had to re-select it for LabVIEW to like it.  You'd be better off using the WinAPI call.
It worked after I rebuilt it.  I included my updated files, as your project did not contain your build specification.
Matthew
Message 11 of 14
(623 Views)
I have seen this before.  I fixed it, but the problem didn't disappear.  In my example, when I open the  "[About Help] - Get App Version Info.vi", the .NET DLL is no longer out dated (see picture), but when I compiled the exe, the error still occur.
What did you mean by using WinAPI call?  What build specification are you referrring to?  I attached everything.
Kudos and Accepted as Solution are welcome!
Message 12 of 14
(609 Views)
When I ran your exe, the error is not data.  When I opened your "[About Help] - Get App Version Info.vi", I got the attached error saying tha a newer dll is loaded instead.  I saved everything and recomplied again, and the error appeared once more.  Howcome my dll doesn't work?
Message 13 of 14
(606 Views)
Try going back an manually selecting the function calls again.  Sometimes LabVIEW won't complain, but it really is not reconnecting everything.
The WinAPI call is here:
http://msdn.microsoft.com/en-us/library/windows/desktop/ms647003(v=vs.85).aspx
Someone already did the work for you though:
http://digital.ni.com/public.nsf/allkb/935BA7FB426305398625711E0055F1FA
they have a dll version and a .NET version of the library.
Message 14 of 14
(594 Views)
