About x,y axis movement programs in LabVIEW
Thank you for your reply.
Is there a function or something that swaps the values of two cluster elements?
I have not studied enough and do not understand the ArrayToCluster function very well... sorry!
Message 21 of 25
(428 Views)
You could just reverse the array before converting to a cluster or you can rewrite the earlier logic so the elements are in the correct order already
(When using "array to cluster", it is also important to define the number of elements of the output. If you don't understand a function, read the help! Is there anything not clear?)
Message 22 of 25
(423 Views)
@altenbach wrote:
... or you can rewrite the earlier logic so the elements are in the correct order already
For example, if you swap the inputs to the two "built array" nodes as follows, the cluster element values would be swapped.
Message 23 of 25
(420 Views)
Data is taken at intervals of 1 μs while moving the tip of the scanning tunneling microscope.
The number of data is 198 x 256 x 256 = 12976128.
From this data, I want to extract data from this data at intervals of 198, such as 1,199,397,595....
Then 65536 data should be extracted.
I want to create an image by placing this at 256 x 256 pixels.
The first step is to place the image from 0 pixel to 255 pixels in the x-axis direction. Next, move 1 pixel in the y-axis direction and place. Then, from 255 pixels back to 0 pixels in the x-axis direction. Then move 1 pixel in the y-axis direction and repeat the process. Please refer to the file(scan1.pdf).
Message 24 of 25
(400 Views)
Thank you very much.
It worked.
Message 25 of 25
(384 Views)
