Acceleration measurement
Dear All
I'm a new labview user
How to measure acceleration and deceleration of a vehicle?
I mount an accelerometer to the cowl panel firewall in a car, but instead of mesuring the vehicle acceleration, the sensor measure the vibration of the firewall panel. What is the correct method to get the vehicle acceleration?
I used IEPE accelerometer with g range up to 500g, frequency range 3-18kHz.
Please advice
Thank you so much
(3,753 Views)
hello hkm. accelerometers are very noisy sensors. you could start by adding a low pass filter. probably one with a cut off frequency at 2hz and see if that's good enough. You could use even lower frequencies.
Check if you have a filter block in your labview package. if not you can program a very simple one and that should be enough.
(3,742 Views)
hi Nihil
Thanks for your feedback. I did use low pass filter, but with higher cut off frequency. I'll try as your suggestion at 2Hz once i work with the test again.
(3,729 Views)
Accepted by topic author hkm
i worked with accelereometers once, we used an accel and a gyro to determinie the roll axis of a platform. we used complementary filters (a lowpass for the accel and a high pass for the gyro) and the cut-off frequency we ended up using was 0.5hz.
good luck.
(3,727 Views)
