Acceleration to Velocity w/ accelerometer on NI 9234 DAQ
@J_K_er wrote:
I'm trying to recreate the functionality of a vibration analysis machine. Right now I'm trying to nail down the overall velocity in units of inches per second.
For this you need to know exactly what this machine is doing..( internal signal processing)
And who tells you that the shown value is correct?  Is there a type approval (acording to what?) or a calibration report ( ISO 17025)?
EDIT: Forget the cal report ... these units are for coarse monitoring ... don't expect to get the same values.
At least you can use a traceable chain.  (Accelerometer and DAQ with cal report, or at least a good uncertainty estination 😉
Next error source would be the same exitation .. magnetic pickups at higher frequencies... at ~30 m/s²....  I would estinate at least 10% error
I would mount both sensors with a bold on opposite sides on one plate and shake that plate.  (and use grease/oil on the mounting surface!)
(in 'my' lab we would use Laserdopplervibrometer and measure on the reference surface 😄  , but that need a good axial exitation ...  )
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 11
(524 Views)
