Acceleration to displacement using labview
Actually i'm using arduino blocks, so this is my scheme.
Message 11 of 14
(1,398 Views)
Just another suggestion, maybe you should work with 1D array waveform instead of scalar values. As you can see, I integrated sin(x) and got the correct response.
Message 12 of 14
(1,383 Views)
Oh!  The Z axis is the easiest to calibrate.  Place Accelerometer Face Up, not moving, take V(up).  Now turn it face down, not moving, take V(down).
Turn back to Face Up.  Now, when testing, you must keep the orientation fixed to exactly Face Up (do you see why?  Think about tilting it 90° and moving it up and down -- no Z acceleration will be measured!).
A(in g's) = (V - (Vup + Vdown)/2) / (Vup - Vdown)/2)
You should be able to derive this formula yourself from the following Equation for a linear accelerometer (which yours is, to a good approximation):
   A(in g's) = V - Voffset / (VoltsPerG)
Bob Schor
Message 13 of 14
(1,371 Views)
I want to thank you for your suggestions, but no one of them work for me. for the procedure that you give me
Message 14 of 14
(1,354 Views)
