Accelerometer Vernier examples
Im working on my final project for labview. I am planning in creating an Earthquake Alarm System for my area and I would like to use the 3-axis accelerometer. The equation I will be using is the Richter Scale formula that calles for an amplitud. I need to see if the accelerometer would serve the pursose of detecting p and s waves that I will simulate using an oscillator.
 I have not been able to find examples of the accelerometer use on labview...any ideas where could i look?
Lara
(3,883 Views)
It would help if you provided us with info regarding what accelerometer you are using. There may not be a specific example for your accelerometer, but knowing how it is interfaced will go a long way towards us helping to point you towards something similar.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,878 Views)
Thank you for replying!
it is a 3-Axis Accelerometer (OC 3D-BTA)
I hope that it is the info you needed!
Lara
(3,867 Views)
Accepted by topic author laralds
If you a talking about this accelerometer you need some sort of interface according to the manual.
Collecting Data with the 3-Axis Accelerometer
This sensor can be used with the following interfaces to collect data:
Vernier LabQuest® as a standalone device or with a computer
Vernier LabQuest® Mini with a computer
Vernier LabPro® with a computer, TI graphing calculator, or Palm® handheld
Vernier SensorDAQTM
CBL 2TM
If you choose or have the SensorDAQ interface then:
Data-Collection Software
This sensor can be used with an interface and the following data-collection software.
LabVIEW National Instruments LabVIEW™software is a graphical
programming language sold by National Instruments. It is used with
SensorDAQ and can be used with a number of other Vernier interfaces. See
www.vernier.com/labview for more information.
The LabVIEW drivers are located here.
Looks like they probably have some examples as well.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,861 Views)
