Accelerometer not running
hi, i need help, i not sure why my accelerometer labview is not running. is it because i need to type the program to run? need helpaccelerometer.png
(3,301 Views)
It always helps to attach code, not pictures of code (with the exception of Snippets, we cannot paste a picture into LabVIEW and try to run it).
You don't really say enough to help us understand what is wrong.  So here are some questions --
  1. Did you push the Run Arrow?
  2. What hardware are you using?  Was it connected to your PC?
  3. What version of LabVIEW are you running?
  4. Do you have the proper Device Drivers for your accelerometer installed?
At this point, it is very difficult to determine if this is a Software or Hardware issue.
Bob Schor
(3,258 Views)
