Accesing Multiple I/O Channels cRIO
Hi guys,
I had taken over the previous code done by my predecessor for the cRIO but the interfacing that he used is not very efficient. In order to write to multiple channels on the NI9403 (32 Channels Digital/Input Output Module), he used a boolean array and indexed the individual values out to write to the Channels which makes the block diagram very big (total of 24 channels).
Is there a better solution to interface with Multiple CompactRIO Channels in Scan Mode to write to the DIO Channels as compared to the existing one?
Model used: cRIO 9074
Mode: compactRIO Scan Interface
Thanks!
Cyongjed
Message 1 of 8
(3,766 Views)
Hi cyongjed,
In FPGA mode you get the option to access the DIO channels of the NI9403 module as U8/U16/U32 value by grouping them like DIO0:7. Then you would need just 2 or 3 IO nodes to acces 24 channels…
As I didn't use the ScanMode on cRIO (too many limitations) I strongly prefer to utilize the FPGA of your cRIO!
Message 2 of 8
(3,757 Views)
Hi GerdW,
Thank you for the reply. I thought of it too initially, but I have some limitations faced here as the FPGA Module was not purchased by my company they only got the RT Module SSL License. Hence kinda restricted to use the scan mode for now till the next sales purchase renewal with NI.
Are there any other suggestions that you could advise me for this case, please? Thanks!
Cyongjed
Message 3 of 8
(3,752 Views)
Hi cyongjed,
in ScanMode your options are limited, so you access each IO pin using its own IO node…
Message 4 of 8
(3,725 Views)
I'm not certain but I seem to remember if you right-click on the module and go to its properties there may be an option there to change the mode in scan mode. Worth checking.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 5 of 8
(3,718 Views)
You can access the I/O programmatically. See the shipping example
<LabVIEW>\examples\CompactRIO\NI Scan Engine\Advanced\Programmatic IO Access - Scan Mode\Programmatic IO Access - Scan Mode.vi
https://tmesystems.net/
Message 6 of 8
(3,690 Views)
Hi ZY,
Thanks for the suggestion. However when I was looking through the examples it is used for all I/O Variables in the Scan Mode. For my case, I only require 24 of them, any suggestions for this please?
Thanks!
Message 7 of 8
(3,677 Views)
Accepted by topic author cyongjed
The example uses a for loop to index all elements in the array. You can wire a value to the Loop Count input to force the for loop to run less iteration.
Message 8 of 8
(3,670 Views)
