Access 2003 vi's compatible with Access 2007?
The short answer is: Yes, it should work.
The ActiveX-commands used should exist and work on both.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(646 Views)
Depending on what extension is used on my computer, a different viewer launches so I always change it to jpg!!!  Personal preference.
Thanks for the answers.
Message 12 of 14
(627 Views)
Then change the default viewer for the .bmp extension to the one you like to use rather than changing the extension.  Changing the extension doesn't change the file format from a humongous bitmap to a smaller jpeg or .png.  Viewers are smart enough to know how to open the file no matter what the extension is, but they don't magically change the file.  At least not until you go and do a Save As to save it to a more efficient file format.  .png's are preferred on the forum because the are small, and do a very good job of showing images such as block diagrams and front panels, where as the compression algorithm of jpeg format, while great for photographs, makes the graphics of LV diagrams and panels look fuzzy.
Message 13 of 14
(602 Views)
Ravens Fan wrote:
[...].png's are preferred on the forum [...]
PNGs from the Code Capture Tool are much preferred because it actually IS your code, rather than a picture of it.  Native LV VI Snippets are a close second. (See my plug for the CCT in my signature.)
Jim
Message 14 of 14
(589 Views)
