Access 7813R in LabVIEW
Hi there,
I wanted to use my 7813R unit in LabVIEW for input and output of digital signals. However I don't know how to access it in LabVIEW.
Can someone tell me how to get LabVIEW to recognise the 7813R for aquiring and outputting signals?
Atommic
(3,943 Views)
It requires the purchase of the LabVIEW FPGA module besides LabVIEW. Do you have that?
(3,939 Views)
Yes I have the NI-7813R FPGA module. I think I have to set up some kind of FPGA target.
(3,936 Views)
Go through the following:
Getting Started With LabVIEW FPGA 8.x
If you have questions, post back!
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,923 Views)
Ok I was able to interface it in LabVIEW. However, if tehre are 68 lines on the SCSI plugs, why are there only 39 channels acessable? Where are the other 29 channels? Are they ground references?
(3,909 Views)
Have you had a look at the manual? (probably the first thing an engineer must do)
NI 781xR User Manual
They are 40 DIO lines, one line for +5V, the other for -5V and the rest are DGND.
Adnan Zafar
(3,885 Views)
