Access I/O Ports from RT without an FPGA VI
I am having only one VI in RT but no VI for FPGA. So, How could I access the input Output Ports without using the FPGA VI. I am using the FPGA Interface Mode.
Thank you.
(2,543 Views)
Guessing you are using a cRIO or something similar.
You just need to use the scan engine to use it directly.
Try these links
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIDfCAO&l=en-US
https://www.ni.com/en/support/documentation/supplemental/08/understanding-ni-compactrio-scan-mode.ht...
If the above doesn't make sense, post details of your hardware and software (version etc)
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,531 Views)
