Access Library File
     I have a static library with .lib extension. I need to access functions using LabVIEW. Is there any way to do the same? If no, Please advice how can I achieve the same in detail.
Best Regards,
Vijay
(3,045 Views)
search for code interface node and also study call library function node
here
(3,030 Views)
What operating system is this? If it's Windows, you cannot call a .lib file directly from LabVIEW. You will need to get a DLL or make one.
Message Edited by smercurio_fc on 08-22-2008 10:09 AM
(3,015 Views)
