Access database and LabSQL
I am making a application to fetch data from a Access database with LabSQL. Does somebody knows if MSAccess needs to be installed on your computer to make this application working. Or is also possible to fetch the data from the database without having Access installed.
Greetings
Davy
(3,585 Views)
You do not need Access. You only need the ODBC driver and MDAC.
(3,585 Views)
Thanx Dennis,
But where do I get the ODBC driver en MDAC.
Davy
(3,585 Views)
Newer OS's already have MDAC installed but you may want to check the link to Microsoft that's on the LabSQL page. You can check to see what you have installed already by starting the ODBC Administrator program. On Win2K its Start>Settings>Control Panel>Administrative Tools>Data Sources. On NT and older its located right on Control Panel.
(3,585 Views)
