Access denied: This target is running a version of LabVIEW that is different than LabVIEW on the host computer.
hi
"Access denied: This target is running a version of LabVIEW that is different than LabVIEW on the host computer. For Real-Time targets, you can verify the version and reinstall the Real-Time software using MAX."
I've got this error when I wanted to connect to the raspberry pi 3b but version of raspberry labview and laptop are compatible in other laptops.
what should I do?
(671 Views)
Hi John,
@johndoew wrote:
I've got this error when I wanted to connect to the raspberry pi 3b but version of raspberry labview and laptop are compatible in other laptops. what should I do?
Use those other laptops!
(Or update your own laptop to the very same version as used in those other laptops…)
(628 Views)
