Access ftp files from file explorer
I am writing an application in LabVIEW where I have to access files on the ftp server. I have added the ftp folder under "Computer" using Add a network location. Now the ftp folder shows under the computer and I can access it like a local folder in windows explorer.
However, if I try to select a file in the ftp folder from LabVIEW, it doesn't let me do that. In the path control I can browse to the file location in the ftp folder but when I hit OK after selecting the file, the file dialog doesn't close.
Is it possible to access file in the ftp folder from LabVIEW?
Ritesh
(7,192 Views)
Accepted by topic author LVCoder
I'm reasonably sure that Windows built the appropriate "wrappers" around the FTP Protocol to allow a "drag-and-drop" and Network Place "folder".  If you want to do an FTP transfer, there is a series of FTP functions (look in Data Communications under Protocols, FTP).  You'll need to do some of the low-level stuff yourself (Windows "does it for you", but LabVIEW "allows" you to do it for yourself).
Bob Schor
(7,173 Views)
My problem isn't about sending or retrieving files FTP. It is about selecting the file in the windows explorer itself and I don't think there is any straightforward solution in LabVIEW. So basically what I have to do is write windows explorer for FTP inside my application.
(7,143 Views)
Well, I can do most of this, the only thing I haven't figured out is how to get the IP address of the FTP Server I want.  Note that this returns a top-level Directory listing -- if you need directories of folders, you need to write additional code.  On my machine, my LabVIEW Real-Time PXI has an FTP Server that shows up in my File Explorer Window -- I can't use its name here, but I can get its directory by its IP, 10.0.1.103.
Bob Schor
(7,119 Views)
Bob,
I researched a little bit to see if there was a direct way to access the files on the ftp server using labview windows explorer but I couldn't find any. So I wrote my own FTP explorer. It was easy to implement as the the ftp ip and port is already known to me.
Ritesh
(7,078 Views)
