Access individual bits of a long data type
I'm using a DLL with LabVIEW at the moment and one of its properties
is to return the version of the DLL as a long integer. The bitfields
are as follows:
[31-24] Major version.
[23-16] Minor version.
[15-00] Build number.
How can I split the long up into the relevant bits so that I can
display the version number correctly?
Adrian.
(2,922 Views)
There is a function on the numeric function palette that turns an integer into a boolean array. You could then index out the bits you want for each portion of the word and turn the array consisting of those bits back into a number. (see attachment)
Note that you could also do it by manipulating the input number directly through logic functions that mask off the unwanted bits for each value and shifting the result. But the readability would suck.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,922 Views)
Hi Adrian,
in your case it is easier to use the "SplitNumbers" from the Advanced/Data Manipulation palette. (see attached example). In a more general way: use an
AND with a mask value and shift the result to the
right accordingly...
Gerd Wieczorek
(2,922 Views)
Adrian Gibbons wrote:
> Hi,
> are as follows:
Your bitfields make things easy by being aligned on byte boundaries.
Have a look on the Advanced palette under data Manipulation, you
should find a 'split Number' vi, which will split a 32 bit number
into 2 16-bit numbers and can then be used to split one of these
further into 2 8-bit numbers.
That should do it.
If you want to split arbitray bits out of a number, have a look at
the 'Num
ber to Boolean Array' Vi on the boolean palette.
Remove "spamkill." when replying to this message
(2,922 Views)
