10-04-2006 10:15 AM
10-05-2006 04:17 AM - edited 10-05-2006 04:17 AM
Message Edité par TiTou le 10-05-2006 11:17 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
10-05-2006 06:58 AM
10-05-2006 07:14 AM - edited 10-05-2006 07:14 AM
Message Edité par TiTou le 10-05-2006 02:14 PM
Epictetus
10-05-2006 09:55 AM
No, you don't need to have Access installed in order to write/read to a database with the toolkit. Access is the UI for an underlying database engine called Jet. Jet is part of Windows. The database toolkit can communicate with Jet without the Access front end being installed. As to the error you are getting, I'm not sure exactly what it means, I usually those errors can be taken at face value and you are exceding some limit on number of rows for the Jet database engine. How many rows are you trying to write/update? What datatypes are involved?
10-05-2006 09:59 AM
At the moment of error, only two records. The first record completes successfully with no error but the second fails.
10-05-2006 10:05 AM
Epictetus
10-05-2006 10:06 AM
Can you post your code?
thanks
David
10-05-2006 10:22 AM
10-05-2006 10:34 AM
Epictetus
