Access needles on a Gauge with two needles
I have a gauge on my front panel with a single needles. When I added another needle, the gauge indicator on the block diagram changed to a cluster type. I need to access each needle and perform operations on them. I tried using the "unbubdle" funciton but it did not work. How do I access both needles ?
(1,777 Views)
Hi santima,
Use the Bundle function (instead of Unbundle) to set the values of both needles…
(1,772 Views)
The needles are being driven already by another value. To be more precise, I need to create a knob reference of each needle but before that I need to be able extract each needle from the cluster having those two needles.
(1,769 Views)
Could you provide the VI that you are having problems with?  I have no idea what you are talking about.  A picture is worth a thousand words, and a VI is worth a thousand pictures, so you can see that it would be orders of magnitude easier for us to provide help if you provided the VI rather than rely on a complicated description.
Bill
CLD
(Mid-Level minion.)
(1,760 Views)
Accepted by topic author santima570
It's really not clear what you want to do; but I'll take a wild guess that you want to create references that you can pass to a subVI that will allow the subVI to access the values of the needles.
(1,744 Views)
This is exactly what I was trying to do. Thanks !
(1,739 Views)
