Access "controls" or buttons on a LabVIEW VI with DLL
Hmmm, I will try this approach and see how it works. I can ask them to enable it and send me a new exe file along with a new DLL to which I can pass parameters. Hopefully, one of these approaches works !
Thanks for all your help, I will come back if I face more hurdles in the above two appraoches.
Message 11 of 14
(913 Views)
What I would do if I was building a dll is, besides having parameters, is to create different functions in the dll that can be called to perform specific tasks. For example, an initialize, a configure, a read, etc. These would basically equate to subVIs that the main front panel would call. I question the programming skills of the vendor.
Message 12 of 14
(906 Views)
As Dennis said, you'll need to work with the vendor. It sounds like they had an existing application, you asked for a DLL, and they gave you the application compiled as a DLL with a single main function to call. I wouldn't jump to the assumption that the vendor is sloppy, though. Did you simply ask for a DLL, or did you give them a specific list of actions you need to be able to perform from the external code? If you didn't tell the vendor exactly what you needed, I can well imagine them doing the quickest thing possible to provide a DLL. Why should they put in extra effort and make it more complicated to call their software - by providing multiple functions in the DLL - if you didn't give them a list of requirements?
Message 13 of 14
(899 Views)
Hello nathand, thanks for your comment ! This is a new development effort on both sides so I could easily see how it may have happened. Also, since the vendor is the owner of the source code, I had assumed what it would take them to do based on our requirements (what all we need to access) from the external code.
Message 14 of 14
(878 Views)
