Access the timestamp value of an EPICS variable
We use EPICS clients/servers on cRIO platforms.  I would like to access the timestamp of when the EPICS variable was updated.  The timestamp is visible in the Distributed System Manager and we can access it from other consoles outside of the LV environment.  Getting the timestamp outside of LV is an "option" when reading the VAL or other fields.
Any suggestions?
(3,017 Views)
Accepted by topic author TecRix
Discovered it myself,,,, right click on the variable on the block diagram,,, show timestamp
(3,015 Views)
(3,014 Views)
