Access to 2020 community beta but not to beta forums
I have access to the LabVIEW 2020 Community Beta, but I can't seem to access the beta forums? I am trying to find the latest version of the LINX toolkit that I can use that works with the beta.
Is anyone able to help me either get access to the beta forums or the latest LINX beta version?
Thanks!
Message 1 of 8
(3,335 Views)
The LabVIEW beta forum is a closed forum.  Sign up here.  Be aware that there is a rather strict NDA; please read the "fine print" thoroughly so you don't accidentally run afoul of the agreement and get kicked out of the beta program.
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(3,282 Views)
Hi Bill,
I already have applied and received access to the LabVIEW 2020 Community Beta (through that link you sent) back in November last year. My LabVIEW beta license says it has 100 or so days remaining.
The confirmation email I received said I had access to the beta forum, however when I used that email to reach the beta portal (where I can download the LabVIEW beta), if I select forum - it takes me to the regular forum. I can’t find access to the beta forum anywhere?
I found an external link that pointed towards the NI Technology Software Preview portal, but I don’t have access to that either. I’m trying to follow the steps in this blog
but I only have access to the old version of LINX through VIPM.
Message 3 of 8
(3,266 Views)
If you have access to the beta forums (which it definitely looks like you should), you should have a little box on the left side of your main forum page named "My Premium Support Portal".  In it should be a link to the LabVIEW beta forum.
For me, it is between the LabVIEW Community box and the "My Groups" box.
Good luck.  🙂
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(3,262 Views)
Hi Bill,
Definitely can't see anything called "My Premium Support Portal".
Following the link in your last post, I get "access denied".
Who should I contact to get my access reviewed?
Patrick
Message 5 of 8
(3,255 Views)
Hi Patrick,
it should look like this:
Message 6 of 8
(3,250 Views)
Hi Gerd,
I do not have that portal link anywhere on my forum page.
I should have access because I received this email back in November:
Patrick
Message 7 of 8
(3,244 Views)
Hi Patrick,
in this case I would write a message to Akos…
Message 8 of 8
(3,242 Views)
