Access to Array defined in DLL
Hello !
I defined a 1D array in a DLL and want to access this array from LabView. How do I pass the pointer to the first element from the DLL to LabView ?
Thanks !
Thomas !
(3,306 Views)
There is an example that ships with LabVIEW that goes into all the details on how to do this. Search for "Call DLL" in the NI Example Finder.
(3,295 Views)
Simple.  Initialize your Labview 1D Array and pass into the Call Library Node.  The Call Library parameter must be defined as such:   Type=Array, Data Type= whatever you need (U8, U16, etc), Dimensions=1, Array Format=Array Data Pointer.
Message Edited by tbob on 11-09-2006 10:20 AM
- tbob
Inventor of the WORM Global
(3,291 Views)
