Access to Current CPU Load Amount?
Hi!
I need to setup a quick application for some critical timing I am trying to achieve.  Windows is really quite poor at achieving this.  What I really need is a real-time system, but I have what I have and I need to do what I need to do with it today.
There needs to be critical timing between two digital IO ports (in the msecs) once a switch is thrown.  If the CPU load is below 2%, I have no problems obtaining the timing I desire.  If Windows is butting in trying to do something in the background, my timing goes to poo.
Is there anyway to monitor the CPU load (w/o actually creating too much CPU load by monitoring it) so that my digital IO timing code does not fire until the CPU load is below some threshold?
Thanks!
-nic
(3,131 Views)
Hi nic
i guess there is a .NET function which can monitor what you need. i also think there is an example code for it on the ni side, but i don´t remember the location.
i found the location. I think this can help you
http://zone.ni.com/devzone/cda/epd/p/id/5405
Mike
Message Edited by MikeS81 on 01-25-2008 10:18 AM
(3,129 Views)
Here we go.  There is an example.  SimpleTaskMonitor that will work for me!  Thanks!
(3,118 Views)
Worked perfectly.  I'm getting about 0.5ms of percision in Windows!  Who knew it would be possible Smiley Very Happy .
(3,094 Views)
