Access to run time type information
I am looking for some information on how I can enumerate run time type information (lists of properties and methods) from within LabVIEW.  For instance, I would like to be able to generate a list of controls on a front panel (this I figgured out), and then dynamically generate a list of properties for a selected control.  Anyone know how to do this one?
(2,700 Views)
Hi 10(nice alias),
If I am understanding you correctly, you are trying to show a list of all the properties for a selected control. There is no list for these properties that you can readily use...you will have to create the properties list manually depending on the type of control.
Ankita
(2,665 Views)
Thanks Ankita.  I might poke around a bit more.  Most languages have hooks into run-time type information for controls and components (like an activeX control) you can query it to get this information and then display it in a property-setting dialog box.  There is most likely something like this in LabVIEW too.
-10
(2,639 Views)
