Access to task Manager for LV 6.1
I would like to access the task manager's process tab so I can periodically record data regarding Memory, Handles and CPU usage as I run my vi. I'm running XP with LV 6.1 for this particular issue. Is there an easy way to do this?
(2,736 Views)
Sounds like you need Windows Performance Counters (http://msdn.microsoft.com/en-us/library/aa373083%28VS.85%29.aspx).
Make a DLL call from a LabVIEW VI using the Call Library Function Node.
Jeff | LabVIEW Software Engineer
(2,701 Views)
