Access to the cFP's name?
I have an embedded application that shall run on a cFP-2120.
To write to it I use FP write with the data I would like to write or read, and an address to the attached IO device:
FieldPoint\VGMController\cFP-AO-200 @4\Channel 1
Now, I wonder if there is a way of avoiding using the name of the cFP (or, extracting it from somewhere, for instance from the IAK file)? The program is running on a cFP, and is supposed to alter the behaviour of said cFP.
(2,913 Views)
There is not a way to programatically extract data from the .iak file.  Only MAX can do that.
You can find the name of the cFP by looking at the text file ni-rt.ini on the cFP target itself.  Look for the Host_Name key in the [SystemSettings] section.  You can use the File I/O>Config File vi's to read the key from the file.
(2,904 Views)
Hi!
   To support centerbolt, I confirm hat this is the only technique (till now), and I've been successfully using it for my latest projects.
graziano
(2,899 Views)
Thx, I'll try this out Robot Happy
(2,876 Views)
