Access violation (0xC0000005) at EIP=0x00007FFE38185B0C
Dear all,
We have the following error: Access violation (0xC0000005) at EIP=0x00007FFE38185B0C
This error is happening in different computers, with different LabVIEW 64bits version and with diferent Windows versions.
I have attached the .txt files of the last error from LabVIEW 2023 Q3 in Windows 11 Pro, but we have similar errors in LabVIEW 2019, 2020 in windows 10.
We have a lot of software implemented in labview with different adquisition cards and now we can´t work due to this error.
The solution that we find was to install LabVIEW 32 bits.
In short: When we drag and drop NIScope Initialize or other NIScope .vi the error appears and LabVIEW close.
Actualizando archivos multimedia
Any idea of what is happenig?
(878 Views)
i use this tread to explain similar problem. i'm using labview 2023 Q3 64 bit on my laptop Win10PRO. If i try to add target to my project i report labview crash (every time that i try to do that)
instead, if i used a labview project that contains the target, and i try to connect to the target labview crash reporting the following exception
Exception: Unknown (0x00000000) at EIP=0x00007FFE93A6CDCF
Version: 23.3.2f2 (64-bit)
the same project works fine in my win 10 pro virtual machine with the same labview version
i reinstall labview twice, the problems persist
best regards
(740 Views)
