Access violation (0xC0000005) at EIP=0x00F928B0
I have recently purchased labVIEW home bundle and installed it on my PC but every time i start the program i get:
Exception: Access violation (0xC0000005) at EIP=0x00F928B0
I have attached the report fies but i honestly have no idea what to try, ive done the usual uninstall and reinstall but still have the same error.
Can anyone suggest anything?
I have attached the error log files from the crash.
(6,683 Views)
Accepted by topic author andylaw
Ok just by random chance i have solved my own issue, the problem i had was that one of the packages i installed through the VI package manager was corrupt and interfered with labVIEW starting up.
I went through manually deleting the packages as the VI manager needed to open labVIEW to do this automatically but after getting the right package labVIEW started perfectly.
Hope in some way this helps someone else.
(6,680 Views)
Thanks for the solution andylaw, which package was the issue. I have the same problem intermitantly. Thanks
(4,291 Views)
Unfortunately I couldn't tell you as I have since stopped using the package and removed it from my machine. I installed the latest version at the time so I would suggest this was the 2017/2018 version.
Sorry I couldn't be of more help.
(4,284 Views)
