Access violation (0xC0000005) at EIP=0x3052D62C
I had this error when i tried to run application (EXE) file create from vi.
Version: 1.0.0.0
I have already repaired LabView but still the same error appear, any help?
Thank you in advance,
Thanya
(3,686 Views)
Are you using a Call By Library Function Node?
When do you get this error? Is it as soon as you launch the exe? Did you send an error report when the error occurred?
Would you be able to post your code so it can be examined for further troubleshooting steps?
RF R&D
(3,645 Views)
Hi Thanya,
To isolate the specific code causing the error, it can be useful to add user-dialogs before and after operations.
By the way, does your code require any special DLLs?
Cheers!
(3,635 Views)
