Access violation(0xC0000005) at EIP=0x7C8219A6
I tried to open the LabVIEW from start-->LabVIEW 2011--> click in (Windows xp), initailly came in task bar and disappears imediately and getting error "Access violation(0xC0000005) at EIP=0x7C8219A6".
Attached the error report and appreciate your help to fix the issues.
Venkateswaran K
(4,769 Views)
If its a particular vi that is giving you the exception, read this =>http://forums.ni.com/t5/LabVIEW/LabVIEW-Access-Violation-Crashes/td-p/2004337/page/3 and this => http://forums.ni.com/t5/LabVIEW/Error-Access-violation-0xC0000005-at-EIP-0x00764624/td-p/1867021
If Labview application is crashing (just starting it!), I would say repair labview (http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001).
If that doesnt solve it, contact local NI support with the crash information!
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(4,759 Views)
Not any specific vi, i was trying to open main LabVIEW application itself. i'm using LabVIEW 2011 evaluation version, 1st time same problem occured so i repaired and restarted my pc, again same problem occured. so i reinstalled LabVIEW and it was working fine for 2 hours and then again same problem occured when i trying to open main LabVIEW.exe.
Venkateswaran K
(4,745 Views)
