Access violation when I try to run RT code
I get this when I try to run my RT VI. Did this in 2011. Upgraded to 2012.F3.
PaulG.
Retired
(3,268 Views)
Hi PaulG,
There are many different potential causes for Access Violation errors.  Without knowing any details about your program, it would be very difficult to narrow down the source of this particular error.   If this is a persistent error, you can contact NI Support with your error report for help with finding the cause of the crash.
Jayme W.
(3,236 Views)
This type of error started happening in many places and still don't have a straight forward answer and also it happens in many versions. You can see here I have reported the same issue with a different condition with 2009 SP1 ( I haven't mentioned there ). Even if NI can't give a solution directly I would expect an answer why this happens because I see a common thing among all the issues is LabVIEW with different platforms.
(3,228 Views)
Accepted by topic author PaulG.
This issue resolved. My project got corrupted somehow so I created a new one with the RT Template. It's not 100% yet but at least it's not crashing any more.
PaulG.
Retired
(3,180 Views)
