Accessing 3rd party OPC-Server when working wit run-time engine
After compiling my project and transferring it to a different PC, it doesn't work anymore: The OPC Server is not started by LabVIEW.
The application itself is partially running, but the data socket access is not.
The OPC-Server itself is working properly.
Is there something more to be installed on the PC (not only run-time engine) or do I have to configure something specifically?
(2,622 Views)
Perhaps there is a setting in the labview ini file, Labview.ini. Copy the
file to the application directory, and rename it to the application name,
application.ini.
Wiebe.
"MichaelKitz" <x@no.email> wrote in message news:172750@exchange.ni.com...
work anymore: The OPC Server is not started by LabVIEW.<br>The application
itself is partially running, but the data socket access is not.<br>The
OPC-Server itself is working properly.<br><br>Is there something more to be
(2,612 Views)
