Accessing Citadel With Microsoft Visual C++ .NET
Has anyone been able to do this successfully? I am trying to write a small program that lets the user filter Citadel data and then output that filtered data to a separate spreadsheet.
My problem is this: every piece of documentation I can find says to use the VC++ Class Wizard to create an "ODBC-MFC Consumer" class and then go from there. When I attempt to do this, and tell it where Citadel resides, it comes up with "Could not find any table or procedure information." It works if I tell it to use an existing Excel spreadsheet, but with Citadel the "Wizard" is just confused.
Does anyone have a way around this, or some advice for accessing the Citadel data using MS VC++?
(3,111 Views)
Tritone,
I am an NI Industrial Automation Applications Engineer but I have no experience at all with Microsoft Visual studio C++.NET. However I do know that you first need to create the data source in order for your application to access the Citadel ODBC driver:
http://zone.ni.com/devzone/taskdoc.nsf/2d17d611efb58b22862567a9006ffe76/ada7d25d95dd50d68625680800729d71?OpenDocument
I found that article on the web about Connecting to Oracle 9 using the Microsoft .NET Framework with source code.
http://www.akadia.com/services/dotnet_odbc.html
The structure would probably be pretty similar to the one provided here to connect to Citadel.
Cyril Bouton
National Instruments.
Cyril Bouton
Active LabVIEW Developper
(3,111 Views)
Same for me, barely experience in C++, but I was once looking for some examples and found:
Querying Citadel 4 Via OLE DB Provider for ODBC in Microsoft Visual Basic
Querying Citadel 4 Via ODBC in Microsoft Visual Basic
Discussion about the ODBC
driver for Citadel 4
Just curious: Why are you using VC++ and not LabVIEW DSC to retrieve the historical data?
Hope this helps.
Roland
(3,111 Views)
