Accessing DDE Server from DSC module over network
i have develope a DDE Server , which works fine when i am accessing data locally via DSC module.
But I am facing problem in accessing it via NetDDE.
on Server I am running my DDEServ.exe , and I have made DDE share aslo. on client side i m making
the attached configuration, but invain. May be i am not setting proper NetDDE application or Topic name.
I wana to access via DSC module and not via Labview VI.
Regards.
(3,294 Views)
I'm curious to know, what kind of behavior you see when you run your client side application, for example are you receiving bad data on this tag?  Does it throw any errors, or tell you that the I/O is not valid when you close the Analog Tag Configuration window?  What operating system are you using?
If you haven't been able to get NetDDE working through the DSC Module, I recommend going through the tutorial in this Developer's Zone article to eliminate the NetDDE configuration as a possible cause of the issue.  Have you gotten the NetDDE communication functioning through a LabVIEW VI?
Cheers,
Matt Pollock
(3,270 Views)
