Accessing a .NET assembly by String reference
The CDapDelivery can either be of type CDapMessage or CDapNotification.  This is the code I need to implement in LabVIEW:
foreach (CDapDelivery DapDelivery in DapDeliveries)
          if (DapDelivery is CDapMessage)
            CDapMessage DapMessage = (CDapMessage)DapDelivery;
            LogTextBox.AppendText(String.Format("received message terminal={0}\r\n", DapMessage.TerminalID));
          else if (DapDelivery is CDapNotification)
            CDapNotification DapNotification = (CDapNotification)DapDelivery;
            LogTextBox.AppendText(String.Format("received notification ID={0} state={1}\r\n",
              DapNotification.MessageIdentifier, DapNotification.MessageDeliveryStatus.ToString()));
Message 11 of 12
(609 Views)
It appears that you're dealing with a C++ class that inherits from multiple base classes. I've never had to use such a class so I don't know if the GetType on the individual list item will return the right base class name. You could try it, I suppose.
Message 12 of 12
(597 Views)
