Accessing a Teststand expression in LabVIEW
I am super new to Teststand
I have a numeric limit test step wherein the limits are a multiplication of 2 floats. I would like to access the limits in VI for simulation purposes. I know that I can access the numeric value with GetValNumber property but I am unable to find the property for an expression like this 0.151*0.9NumericLimitTest.PNG
(4,762 Views)
I'm not sitting at a PC with teststand.  But, have you looked at the step itself for properties to see what is there?  I'd expect to see a limit as one of the properties.  With that, you can access the property and send it to LV as one of the inputs to your module.
I wouldn't think you'd need the extra function call to get the number out of the property.
(4,726 Views)
I can access a limit in the VI as in the picture. But if I try to access the limit  as I have mentioned above, it gives me a 0. I want to know which property I should use.Prpoperty.PNG
(4,707 Views)
Accepted by topic author GoKu25
Hello GoKu25,
can you please try Step.Limits.LowExpr or Step.Limits.HighExpr as a string?
Hope it helps
best regards
Alexander
(4,703 Views)
Duplicate thread over on the TestStand board: Access Numeric limit test- limit expression in vi
(4,690 Views)
