Accessing cDAQ-modules from 2 different computers ??
I am maybe asking a hopeless stupid question here, but working from the thesis that there is no such thing, here goes;
If I have a NI cDAQ-9188XT with a NI-9401 DIO module, where I use 4 lines for digital output and 4 lines for digital input,
is it possible in any was to access these 8 lines from 2 different computers more or less simultaneously ?
(2,991 Views)
Yes, but not directly.
Set up one computer to directly talk to the cDAQ.  From that computer, either update deployed shared variables for other PCs to read or setup a network with another form of communication such as network streams or TCP/IP.  The first method doesn't require the second computer but is lossy (it won't check to see if other applications read the updated variable).
(2,975 Views)
