Accessing executable while running LabVIEW
Hi there,
Okay, I'm creating this VI in LabVIEW that uses SystemExec.vi to run an external, DOS-based program. However, this external program needs input after output of the first segment of text. The input is found using a small Call Library Function, but is BASED ON what the program outputs during its first segment.
So, if you couldn't tell already, I'm having a problem getting the output of the first segment into LabVIEW so I can work with it. In SystemExec.vi, when I set "Wait Until Completion?" to "false", there is no output from the sub-vi. Thus, I can't work with it.
Basically, during the whole execution, I need to have LabVIEW able to interact with the program. But it looks like the program
outputs to ONLY ONE device, either the console or LabVIEW. Any suggestions?
(2,975 Views)
Bonhomme-
I answered your question in the other question you posed with the same description entitled:
Can LabView interact with an executable?
ben schulte
national instruments
(2,975 Views)
