Hi, my name is Matthias.
I am working (as a noob) on LabView 7.1. After I have done some vis myself I am facing some troubles now and hope, someone can help.
1.) I have installed lvwutil32 library, that offers some system functionality. Part of this library is WINUTIL.LLB. The library offers most of the functions I will need for my project. But something is very strange about this library: Some vis do not appear/ are invisible/ are not usable through the user library menu, although they are part of the library (and listed as vi). There is a Screenshot attached, showing the content of my WINUTIL.LLB. I have marked all vi that have an icon in my user library menue. As You can see, there are some vis (plz ignore the control) that are part of the library, but I can not use them in my own vi as I can't select them. The Icon is missing in my user library sub menue. As You can see, I already marked all vis as top-level vi (this was a hint of a pal). But that didn't fix the problem. The icon of the vi "Set Window Z-Position" is still not available (see also second Screenshot).
How can this problem be resolved?
2.) Another Problem is, that I was experimenting/ trying some features and I created a second library Icon that I cannot delete. The option Tools/ Advanced/ Edit palette views.../ Delete SubMenue is not active/ can not be selected. The second screenshot is showing the two (similar) icons and in adition to that You can see, that the vi "Set Window Z-Position" is in fact not accessible from the menue.
How can I delete SubMenue Icons that have been created by mistake (are existing twice)?
If there are any more details to mention, let me know.
Thanks in advance!
Matthias
