Accessing shared memory location
I have a space of shared memory that another application has created with a constant handle. How can I get Labview open up this space of memory without having to write a CIN?
(3,424 Views)
There is no built-in LabVIEW functionality to access shared memory. Although you do not have to use a CIN, you will probably have to use a DLL. There is documentation on Microsoft’s site:
MSDN.com: Using Shared Memory in a Dynamic-Link Library
You'll want to use a file-mapping object to set up memory that can be shared by processes that load the DLL.
There are also a couple discussion forum posts that provide some examples from other customers who have tried this:
DF: Communicating Between Built LV Apps
DF: How can I create a DLL with LabWindows/CVI with shared memory?
Hope this helps. Good luck!
Kileen
(3,388 Views)
