Accessing shared variables from a C# application
I hope this question is posted in the appropriate forum, my apologies if not.
I'm building a C#, WPF application on Windows 7 Pro that aggregates data from multiple sources, one of them being a cRio 9025 + 9144.
I have a vi running on the same computer that displays data coming from the cRio and allows me to control and monitor my devices. This vi works with no problem. What I would like to do is to read and write the shared variables this vi is using to communicate with the cRio, but from the WPF application.
I have searched and investigated, but I can't find a really good solution. For instance, I could run a small vi that reads a shared variable and returns its content, but it sounds like a lot of unneeded code is being executed, and it's probably quite slow.
Also, during my investigations I have got messages that my license must be activated to access NI .NET components, but I have no clue which license to activate or buy. I have Labview 2012 and I have activated every license I could, to no end.
Could you kindly point me to a source explaining the best approach to take?
Thank you for your help.
(3,746 Views)
Could you post your VI just in order to see what you've done?
Thank you.
Celine
National Instruments France
(3,713 Views)
Sure. I have attached the project, with the vi running on the PC included. I think vi that run on the cRio or 9144 are irrelevant to the discussion, but let me know if you need more.
DLB
(3,697 Views)
@Proengin wrote:
Also, during my investigations I have got messages that my license must be activated to access NI .NET components, but I have no clue which license to activate or buy. [..]
Those libraries are part of Measurement Studio (MStudio), an "add-on" to MS Visual Studio:
Maybe it is easier for you to buy MStudio (either as standalone or as part of the Developer Suite Core) rather than trying to create a LV wrapper and include this as unmanaged package in your C# application.....
Norbert
Norbert
Expert: Geometry
(3,687 Views)
I have Measurement Studio Enterprise Edition installed and activated on my computer. However, I might have missed a step somewhere, and I will focus on running the examples and reading the doc (!) until my license issue is fixed.
Anyway, that's the pointer I was looking for, thank you. I'll come back here if I still can't make it to work.
DLB
(3,679 Views)
