Accessing the non-volatile memory from LabVIEW FPGA
Is there a way to access the non-volatile memory directly in the LabVIEW FPGA, for sbRIO-9651 SOM?
I would like to run the FPGA immediately after the power up and read some parameters from the memory, without involving the RT.
Arun
(1,138 Views)
(1,096 Views)
Thanks for the response. However I am specifically looking for the information about the FPGA code fetching some data from the non-volatile memory, once it has been loaded from the flash memory and started running. This data would have been written to the non-volatile memory in the previous power cycle, before powering off.
Arun
(1,076 Views)
