Accumulation
I have problem of doing accumulation from acquired signal. I have used shift register to do so but it took long time. There is an alternative way??
(2,718 Views)
Do you mean the sum of all measured values?  As in the sum of all array elements?
If so, in the Functions Palette, look under Numeric and look for "Add Array Elements"
(2,706 Views)
