Accumulator in FPGA
I need help to do a specific accumulator.
Data is retrieved in FPGA by an array of 2 consecutive sample
I need to do an accumulator with input N, N+1, N+2, N+3, etc.
If the input is only 1 sample, the function exist un FPGA module. Here, the problem is that I retrieve 2 samples each time.
How do an accumulator with theses inputs ?
(3,315 Views)
Hi Minikisscool,
you might do the math on your own without any specific "Accumulator" function.
Or you might call the Accumulator function twice in a loop…
(3,296 Views)
In LabVIEW standard, I have the code, but in FPGA, i use a Single-Cycle Timed Loop in FPGA acquisition...
(3,273 Views)
Hi Minikisscool,
in "standard" LabVIEW you should use autoindexing on the loop input tunnel too!
Maybe you need something like this in LV-FPGA:
(3,268 Views)
