Achieve 3D position measurement with Accelerometer
Achieve 3D position measurement for the 3 coordinate axes X, Y and Z using the NI USB-6008 data acquisition device and an auxiliary board  with 3-axis Accelerometer.
Best regard.
(2,112 Views)
Do you have a question?
(2,107 Views)
I found the title in the book, but there is no answer. I can't figure it, I'd like to ask you guys. There are topics in the annex. Thanks.
(2,097 Views)
Hi CKnotcalvin,
In which book did you find this homework?
Maybe there is no answer because it is homework, which you should solve on your own?
When you cannot solve this homework yet, then you should take the "Training resources" as offered in the header of the LabVIEW board. And you can examine all those DAQmx example VIs coming with LabVIEW?
Which of those "annexes" are unclear to you?
(That "annex" about creating the AI channels is unclear to me: why do you need 3 "Create Virtual Channel" calls for your homework? You need just one instance…)
(2,068 Views)
Hi,GerdW
Thank you .. I would like to have a try.
(2,047 Views)
