Acquire Images from webcam in LabVIEW 8.5
I've been working with Labview for week now and have done several online tutorials and things like that. I need to be able to record an image from a webcam into Labview. I've found numerous discussions on the topic but none that contain any solid examples. I have Labview 8.5 with the NI-IMAQ drivers and NI Vision.
What are the basic steps that need to be done to aquire an image from a webcam and display it on a front panel? Any example VI's or detailed descriptions would be more than welcome. Please understand that I have just started working with LabView so some concepts like device drivers are still a little new to me. Thank you for any help you can provide.
(6,569 Views)
Hi Dejay,
You are not clear of which webcam u are using.
If u are using an USB cam
this would definitely help u.
C:\Program Files\National Instruments\LabVIEW 8.2\examples\IMAQ\imaqUSB examples.llb
Cheers,
Suneel.V
(6,565 Views)
What about in labview 8.5? there is no IMAQ folder?
(6,011 Views)
Hello CanadianKyle
 U can download ni_imaq_usb_installer_86.exe from ni.com website so u can get IMAQ Files in your LabVIEW 8.5.
It loads the IMAQ files in your labView so that u can use them to acquire images from that inbuilt VIs.
Best Luck........
(5,984 Views)
Is there anyway to use this without having Vision 7.1? (quite an expensive add-on!)
(5,961 Views)
Hi CanadianKyle,
I've been working with Labview for few months now and have done several online tutorials and things like that.
but i can not tell you exactly that Vision requirement is must or not?......
But I Think there is no other way to use this without Vision 7.1 or Higher.
U will get Vision with evaluation version on Ni.com.
You can try for this, It will help you.
best luck.
(5,936 Views)
