Acquire N Scans doesn't work
Acquire N Scans VI (it is an example VI) does't work to collect noise ( no input connected)
(3,269 Views)
I'm not quite sure what you mean. If you mean that the A/D card delivers no values when there's nothing connected, then I'd contact whoever sells the card. If you mean that the LabVIEW function doesn't work without wiring channels to it, then I agree it doesn't work.
You need to wire a channel to the function to let it know from which hardware channel of your A/d board to read. If there's nothing physically connected to the card, you'll measure noise.
Hope this helps
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,269 Views)
The problem is: I don't measure noise, but I measured it before. So, the problem is not the device (it is a PXI-4472) but it is in Labview. Nothing has been modified. Yesterday it worked, today it doesn't work.
Look at the VIs: they are extremely simple. Cont Daq and Acquire N Scans are the same as those in the Example Fider. Only ACQ&Wite has been little modified. They acquire only if signal is more than 0.465 V pk-pk.
(3,269 Views)
I only have the evaluation version of LV 7 on my computer, and I don't have any DAQ installed for it. Therefore, I can't test the program. I have seen, however, that you send "0" to the parameter for "number of scans" for the AI Start function. Is this correct for continuous scans, or should this not be "-1". This should have absolutely nothing to do with 0.465V as a threshold though..... sorry if I can't help more, but I don't have the VIs on my computer, and therefore don't have any help for them either.
Some functions also default to device 2 instead of device 1. Is this intentional?
Shane.
(3,269 Views)
The question is: have you ever heard that some DAQ VI don't work if input signal is too low? It seems quite strange.
(3,269 Views)
The only thing I can imagine is if the input range is set too high (The gain too low) so that the resolution is too low to detect any better then +- 0.465V. +-0.465 V is a HUGE threshold if this has anything to do with resolution! Are you sure it's Volt, and not Millivolt?
Shane.
(3,269 Views)
