Acquire and generate a signal
Oh I see, the substraction isn't right just deleted it.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 11 of 23
(1,600 Views)
Hi Koen,
Actually, it is running without error, but nothing shown in data graph. It seems the code doesn't read the signal that is generated.
Khalid
Message 12 of 23
(1,597 Views)
Hmm, strange. Did you connect everything right?
Are the physical channels filled in right?
Is the read function compatible with your phyical channel, it's now on 1channel1waveform.
Message 13 of 23
(1,572 Views)
Hi Koen,
Actually, I have connected  A 12 with Ao0 and AI GND with Ao GND and every things as before. However, I noticed in the new code, you replaced  the mode of reading from continuous to signal sample. Is this cause problem?
Khalid
Message 14 of 23
(1,568 Views)
Yes probably that wasn't my intension, try it.
Message 15 of 23
(1,563 Views)
Hi Koen,
Thank you so much for the help. Actually it is working with replacing the mode to continuous sample and the performance of the response is enhanced. However, the x axis of reading graph (time), it seems to be multiply by the number of the sample comparing with time of generation. How I can solve this problem. I have attached the VI and copy of the front panal that shows a difference between the time of generation and reading.
 Khalid
Message 16 of 23
(1,550 Views)
The x axis of the input graph are the acquired samples.
When I look at the vi, it is put on 1ChanNSamples with samples on 200.
The x axis represents those samples, if you higher the amount of samples you higher the x axis maximum.+
Message 17 of 23
(1,544 Views)
Hi Koen,
How I make the x axis of the input graph acquiring samples with real time instead of representing the number of samples.
Khalid
Message 18 of 23
(1,537 Views)
Hi Khalid,
To be honest I'm not so familiar with waveforms.
I changed the vi a bit. Hopefully it will now use the dt from your other waveform.
Don't forget to change the read function again.
Koen
Message 19 of 23
(1,529 Views)
Hi Koen,
Actually, the problem as before, nothing shown in graph that display the input  signal.
Khalid
Message 20 of 23
(1,522 Views)
